Multiple Tilts in one brewery?
trmccart
Post by trmccart »
Hello,
I am looking at using the Tiltbridge project (https://tiltbridge.com/) to get Tilt data to Bierbot Bricks. Can the Bierbot tilt api support multiple Tilts (different colors) in the same brewery with data sourced from the same IP? (At the moment I only have a single Tilt to test with.)
Thanks!
Re: Multiple Tilts in one brewery?
Hey there!
Yes that's possible! Only thing you already figured out: colors need to be different. At least without tilt bridge ;)
Maybe you can report back if you tested it so other know?
trmccart
Post by trmccart »
Great! Thanks for the response! I'll report back after I do a bit more investigation.
One more question... how does Bierbot use the Tilt "Timepoint" attribute in the posted data? The esp32 used for Tiltbridge may not be the most precise with timing. Is this a concern?
Thanks!
We use the timestamp when the message reaches our backend :)
