Hi guys,
just started to create my brewing automation with BierBot and Raspberry Pi 4. It was not a problem to create a brick and add two relays for heating and circulating. So far so good. Next step would be that installation routine is searching for an existing temperature sensor. In my case it's a 2wire PT1000 connected to a MAX3185 board. This board is already connected to GPIO17 (CS), PiMOSI (SDI), PiMISO (SDO) and PiSCLK (CLK) when the when hitting return. But the message is that no sensor can be found.
General questions are if BierBot supports this sensor constellation and if so, does anybody has experience with it and can help me?
THX
