BierBot Bricks app
Vinnes Beer
BierBot Bricks app
Post by Vinnes Beer »
Hello
I have a Google pixel 7 phone and cannot install the BierBot Bricks app.
Is it because the app is only in 32-bit? Is it complicated to post it in 64-bit version?
Arne
Re: BierBot Bricks app
Hi Arne,
thanks for reaching out. The app is currenty way behind the web version. I'd recommend opening the web-app (bricks.bierbot.com) and adding it to your homescreen. Feels (almost) the same.
Releasing native apps will receive more attention from me, when I start implemented a notifaction system (i.e. "active device offline" or "add hops now").
Vinnes Beer
Great, thanks it was a good solution when the phone is not responsive.
Arne
jhon213
Post by jhon213 »
Hello,
I recently downloaded BierBot Bricks app from https://apktact.com/ and successfully installed it on my device, so I might be able to help! If the BierBot Bricks app is only in 32-bit, it could indeed be the issue since the Google Pixel 7 runs on a 64-bit-only architecture.
The best solution would be to check with the app developers to see if they plan to release a 64-bit version. In the meantime, you could try compatibility modes or alternatives, but there’s no guarantee they’ll work.
Let me know if you need more help!
sumit02
Post by sumit02 »
That's helpful to know, thank you!
I'll explore the compatibility options and see if the developers have any updates on a 64-bit release. Your suggestion gives me a good starting point.
Regards,
Sumit.
I'm a software developer working on amazing projects.
