Ds18b20 temperature sensor not detected
Diggerg
Post by Diggerg »
I've tried 3 different probes and none appear when I try to set up my biab profile. Gpio inside is enabled on my pi. Ordered another probe just to be sure. Any ideas?
Re: Ds18b20
Hey Diggerg,
sorry to hear that! A few ideas:
- Check if you have the resistor (4.7kOhm) connected between 3.3V and Data (usually white)
- Check that you connected it to the right GPIO (GPIO 4)
- Same goes for 3.3V and GND. Maybe try other 3.3V or GND GPIOs.
- It should be covered by the steps in the tutorial, but you activate w1 explicitly (that's the protocol that's used to read out temperatures) like i.e. described here.
- Make absolutely sure, that the connections are snug. This is crucial (and I fucked this up many times).
Diggerg
Re: Ds18b20
Post by Diggerg »
Yeah still no luck. I'll wait till my new probe turns up and try again. Used both 3.3v outputs and different grounds but no reading
Diggerg
Re: Ds18b20
Post by Diggerg »
Ok so probe number 4 is no different. Still not showing
Diggerg
Re: Ds18b20
Post by Diggerg »
Interesting that you use 3.3v on the pi but 5v on the Arduino to run a ds18b20
Re: Ds18b20
Unbelievable.
Another idea: connect them to the 5V instead of 3.3V (in theory the DS18B20 supports a range from 3-5.5V)
Diggerg
Re: Ds18b20
Post by Diggerg »
I have been reading online ( dangerous I know). Do I need to install any extra script for 1 wire even though it is switched on in preferences? Or is it all in the bierbot software?
Re: Ds18b20
hmmm, really strange. There seems to be one systematic thing ...
Let's do it the other way round can you share:
- An image of your raspberry Pi settings screen for switching on/off peripherals?
- An image of your Raspberry Pi and the connected GPIOS
- The content of your config file (bricks.yaml)
Anything else where you think it might be important?
Thanks,
Diggerg
Re: Ds18b20 temperature sensor not detected
Post by Diggerg »
It can't even see the probes in script so I'm going to wipe my SD card. Reinstall raspian and start again. Would my existing API still work?
API will still work!
