Multiple Tilts in one brewery?
trmccart
Post by trmccart »
Hello,
I am looking at using the Tiltbridge project (https://tiltbridge.com/) to get Tilt data to Bierbot Bricks. Can the Bierbot tilt api support multiple Tilts (different colors) in the same brewery with data sourced from the same IP? (At the moment I only have a single Tilt to test with.)
Thanks!
Re: Multiple Tilts in one brewery?
Hey there!
Yes that's possible! Only thing you already figured out: colors need to be different. At least without tilt bridge ;)
Maybe you can report back if you tested it so other know?
trmccart
Post by trmccart »
Great! Thanks for the response! I'll report back after I do a bit more investigation.
One more question... how does Bierbot use the Tilt "Timepoint" attribute in the posted data? The esp32 used for Tiltbridge may not be the most precise with timing. Is this a concern?
Thanks!
We use the timestamp when the message reaches our backend :)
kimon
Post by kimon »
Yes, the Bierbot Tilt API can support multiple Tilts (different colors) in the same brewery even when data is sourced from the same IP. Each Tilt is identified by its unique color, so as long as your Tiltbridge setup is configured correctly to send data for each color to the Bierbot API, the system should handle it without issues.
sumit02
Post by sumit02 »
Hello.
Does the Bierbot Tilt API allow customizing the frequency of data updates for each Tilt color in the same brewery setup?
I'm a software developer working on amazing projects.
