Using Different Temperature Sensors (MCP9600)
Posted: Mon Jan 16, 2023 7:17 pm
by Peter
Hello everyone
New to BierBot and I am trying to use a MCP9600 temperature sensor connected to a raspberry pi 3 over I2C serial port. I know the sensor works fine with the Pi but when running BierBot set up it does not find the temperature sensor. I believe this is because BierBot uses W1ThermSensor to find and get readings which does not seem to support the MCP9600.
My current thoughts on a solution are changing main.py and setup.py where W1ThermSensor is used to an alternative which works with MCP9600
Any advice would be greatly appreciated
Re: Using Different Temperature Sensors
Posted: Tue Jan 17, 2023 6:25 am
Hi Peter,
cool you're giving BierBot Bricks a shot!
The software currently indeed only supports DS18B20. So your assumption is correct.
As the code is open source you're very welcome to add that functionality and submit a pull-request (PR) to include your changes for everyone in my repo. Another user already did something similar (https://github.com/BernhardSchlegel/Bie ... rryPi:main) but did not submit a PR (yet). Maybe you already knew parts of this
So your current thoughts are absolutely valid! Maybe a a prompt before "confirm(f"Do you want to scan for temperature probes now?",default="y")" asking "Which type of temperature sensor do you want to scan for (DS18B20, MCP9600)".
Go ahead and create a fork. If any questions should arise (I'm not too familiar with MCP9600) along the way let me know, i.e. here.
Re: Using Different Temperature Sensors (MCP9600)
Posted: Sun Jan 22, 2023 3:32 pm
by Peter
Thanks for your response. I have made a fork on GitHub adding MCP9600 compatibility
https://github.com/JohnMcClane4/BierBot ... aspberryPi
Thanks
Posted: Sun Jan 22, 2023 4:29 pm
Hi Peter,
code looks nice! :) Do you want to submit a PR?
One comment: instead of `for sensor_type in ("w1", "mcp9600"):` I'd do for "sensor_type in ["w1", "mcp9600"]" to use a list instead of a tuple..
Did you (test) brew already?
