Error communicating with SonOff while flashing
Good Evening,
I am getting an error when trying to flash a THR320D. The recommend flash software is reporting an error communicating and recommends lowering the speed. I have taken it down to the bottom speed 115200 with the same error though it does seem to start flashing. I accidentally started with the FT232R set to 5V. This is also my first time ever trying to solder. I'm assuming its my bad solder causing the error.
Thanks,
ChuckG
Re: Error communicating with SonOff while flashing
Hi ChuckG,
not snugly fitting rainbow cables or really bad soldering can cause connection issues here (voltage in the cable is switched from 0 to 3.3V mutliple thousands of times per sec). But I'd blame it more likely on the rainbow cable connection or that you roasted the ESP32 with 5V, soldering has to *really* bad to have an effect.
Happy to look at your pictures to search for an error if you want to post your setup.
A very common mistake is to connect RX to RX and TX to TX instead of RX-TX and TX-RX.
Please let me know how you resolved it!
Cheers and good luck,
