SONOFF TH Elite 16A/20A
Posted: Tue Jul 18, 2023 8:20 am
by ubguest
Hello Bernhard. Is there support for this device?
The old device type can no longer be found. Bought this device.
Re: SONOFF TH Elite 16A/20A
Posted: Tue Jul 18, 2023 8:25 am
Hey,
yes, there is, see this Repository:
https://github.com/BernhardSchlegel/Brick-32 and a YouTube video
https://www.youtube.com/watch?v=5TI9fxsTRmM
However, the display is not supported yet - Pull Requests are welcome!
Posted: Tue Jul 18, 2023 9:38 am
by ubguest
Thank you, Bernhard... And after flashing, can I update the software over the air?
Posted: Tue Jul 18, 2023 10:01 am
Unfortunately no, because the chip flash is less than 2x the firmware.
Posted: Tue Jul 18, 2023 10:14 am
by ubguest
And, now I understand why you are introducing wires from the case!
Any plans to use dry contacts?
For example, connecting a circulation pump via a relay or a distillation valve?
Posted: Tue Jul 18, 2023 12:38 pm
As far as your image says, the dry-contact is always in sync with the relay. If this is a software limitation by Sonoff, feel free to submit a PR to change that - I've open sourced the firmware for a reason (=to allow collaboration and people to contribute).
Current solution, if you want to control a circulation pump indepdentently would be to get a second Sonoff and map its relay to the circulation by drag and dropping in our software. This is the usecase described here:
https://docs.bierbot.com/using-bricks/e ... types/biab
Posted: Sun Jul 23, 2023 12:11 pm
by ubguest
Bernhard wrote: ↑Tue Jul 18, 2023 12:38 pm
Bernhard, you are too kind to people!
Unfortunately I'm not a programmer. In any case, you are doing a good job, thank you very much.
Posted: Sun Feb 11, 2024 3:39 pm
by ubguest
Greetings, Bernhard! Hasn't there been any offline use of your brainchild yet? For example, through iOS or Android applications?
Posted: Wed Feb 14, 2024 10:05 am
Hey,
there was an Android app (which was also communicating with my backend), but taking care of multiple release streams (web and apps) takes curently too much time.
Sorry,
