BierBot Bricks app
Posted: Sun Jan 21, 2024 11:51 am
by Vinnes Beer
Hello
I have a Google pixel 7 phone and cannot install the BierBot Bricks app.
Is it because the app is only in 32-bit? Is it complicated to post it in 64-bit version?
Arne
Re: BierBot Bricks app
Posted: Sun Jan 21, 2024 3:55 pm
Hi Arne,
thanks for reaching out. The app is currenty way behind the web version. I'd recommend opening the web-app (bricks.bierbot.com) and adding it to your homescreen. Feels (almost) the same.
Releasing native apps will receive more attention from me, when I start implemented a notifaction system (i.e. "active device offline" or "add hops now").
Posted: Sun Jan 21, 2024 6:47 pm
by Vinnes Beer
Great, thanks it was a good solution when the phone is not responsive.
Arne
Posted: Thu Nov 28, 2024 6:33 pm
by jhon213
Hello,
I recently downloaded BierBot Bricks app from
https://apktact.com/ and successfully installed it on my device, so I might be able to help! If the BierBot Bricks app is only in 32-bit, it could indeed be the issue since the Google Pixel 7 runs on a 64-bit-only architecture.
The best solution would be to check with the app developers to see if they plan to release a 64-bit version. In the meantime, you could try compatibility modes or alternatives, but there’s no guarantee they’ll work.
Let me know if you need more help!
Posted: Fri Nov 29, 2024 9:13 am
by sumit02
That's helpful to know, thank you!
I'll explore the compatibility options and see if the developers have any updates on a 64-bit release. Your suggestion gives me a good starting point.
Regards,
Sumit.
