cant add pi brick
Posted: Fri Feb 16, 2024 6:54 pm
by Giladbob
hi,
i have problems adding pi brick,
i installed the Pi as instructed, after adding the API key i configured relays and also temperature sensors , i reset and pi wasnt found under bricks .
i dont understand what im doing wrong
Re: cant add pi brick
Posted: Fri Feb 16, 2024 7:13 pm
Hey Giladbob,
Sorry to hear that. Please send the content of your bricks.log. happy to help.
Posted: Sat Feb 17, 2024 4:40 am
by Giladbob
Can you direct me please where I can find the log file ?
Thx
Posted: Sat Feb 17, 2024 5:34 am
Same folder where the main.py is
Posted: Sat Feb 17, 2024 7:56 am
by Giladbob
2024-02-16 22:42:18;INFO;read config
2024-02-16 22:42:18;INFO;apikey=LzxxxxxxxxxxxxxxxxxxxxPA, device_id=python_RaspberryPi_61339140-ccfa-11ee-8c20-d83add31653d, platform=RaspberryPi
2024-02-16 22:42:18;INFO;BierBot Bricks RaspberryPi client started.
2024-02-16 22:42:18;INFO;setting GPIO to GPIO.BOARD
2024-02-16 22:42:18;INFO;initializing relay 1 (GPIO 17)...
Posted: Sat Feb 17, 2024 6:23 pm
by Grummel
I had the same problem have you chose the BOARD numbers of the GPIOs? Use pinout or google to find the right numbers gpio 26 = GPIO 37 in BOARD number. Try it it was my mistake and i spend a lot of time to find the problem.
Sorry for my horrible english
Posted: Sat Feb 17, 2024 6:25 pm
by Grummel
I think you have the same Problem because gpio 17 in Board number is +3,3v
Posted: Sat Feb 17, 2024 7:41 pm
by Giladbob
Wow I feel stupid!
Thx a lot , it work , didn’t read the instructions right, reading it again after receiving from you the answer shocked me ,
I need to do this kind of things when I’m not tired .
Thanks again
Gilad
Posted: Sat Feb 17, 2024 9:06 pm
Thanks Grummel for jumping in!
Happy to hear it worked, Gilad.
