Program on pi startup
Giladbob
Post by Giladbob »
I think I have done something wrong after running setup using terminal I was asked if I wish program to run on startup I chose yes and I run setup several times now I have 5 instances of program running on startup , how do I cancel this ??
Re: Program on pi startup
may sound stupid, but: Have you tried turning it on and off again?
Reason: A singular bierbot.service is file is created, if you run the setup more than once, the file is overwritten. But every time the service is started (
sudo systemctl enable bierbot.service
). Now if you reboot, the service should only be started once.
Best,
Giladbob
Post by Giladbob »
Thx for replying,
Yes I have tried to reboot, power shutdown, remove of browser and end reinstall, nothing works
