Hydrometer API documentation
JoDaNl
Post by JoDaNl »
I'm doing some development work some some weeks now. I'm have extended my BookesBrick with and graphical LCD screen and am fiddling around with a prototype of a bluetooth based Hydrometer (like an iSpindel).
The BookesBrick with act as a gateway and send hydrometer data to the backend.
As such my question : is these some documentation available of the Hydrometer API ?
Regards,
Jos.
Re: Hydrometer API documentation
Hey Jos,
I'll enhance the docs tomorrow for you. In the meantime you could check the open source iSpindel implementation for Bricks support.
So you can check the iSpindel code here https://github.com/universam1/iSpindel/ ... l.cpp#L792
Specifically relevant is to set the following fields
- sender.add("s_number_wort_0", Gravity); // I recommend °P, but you can chance to SG in the Bricks' settings
- sender.add("s_number_tilt_0", Tilt);
optional but helpful (in the future :))
- sender.add("s_number_voltage_0", Volt);
- sender.add("s_number_wifi_0", WiFi.RSSI());
