Page 3 of 3
Re: Brew/Fermentation temperature versus used Brick
Posted: Mon Dec 04, 2023 1:34 pm
by JoDaNl
I really like this, having a separate API to query devices & related information. Very nice!
I tried to get this working. I enabled the Pro-API (note : some additional translation work to be done as I think there are some new string in your code), but had some troubles. Based upon the documentation I tried the following:
https://bricks.bierbot.com/api/devices/list?apikey=XXXXXXXXXXXXXXXX&proapikey=YYYYYYYYYYYYYYYY
But this results is a 'Page Not Found' error.
When I change the url into:
https://bricks.bierbot.com/api/devices?apikey=XXXXXXXXXXXXXXXX&proapikey=YYYYYYYYYYYYYYYY
I get the following response : ["U2iFFOgA550767wrql0","zOYW2N1559jjFvlY5"]
I must be doing somthing wrong here I guess.
Regards, Jos
Posted: Mon Dec 04, 2023 1:44 pm
Hi Jos,
had an error in the exporting. Fixed now in docu
1. Query
https://brewbricks.com/api/devices
to get a list of device IDs
2. Pass one device ID to
to get details for one specific device.
Hope this helps,
Posted: Mon Dec 04, 2023 5:56 pm
by JoDaNl
Hi bernhard,
Thanks for the quick update. I managed to got my test-code working. I'm able to query the Pro API.
I now can easily read the target-temperature/set-point of my fermenters and show it on the display.
Will release the next rev of Bookes Brick shortly...currently busy with another project ;)
Thanks again for your support in this.
Regards,
Jos.
Posted: Mon Dec 04, 2023 6:46 pm
Glad it worked!
Posted: Thu Dec 07, 2023 10:49 am
by JoDaNl
One thing popped up. When calling the (non-pro) API using 'type=bookes' an array of device-id's is returned.
I noticed some 'escaping' of quotes & array. FYI : the Pro-API does not do this.
I'm using the ArduinoJSON library for parsing the returned array of device-id's...somehow this does not work correctly as the .size() member-function always returns 0, even if the JSON string contains this 'escaped' device-id.
For testing this I did a string replace, removing the backslashes & quotes surrounding the array. See below:
[COMMS] response TEMP (received)  {"error":0,"error_text":"","warning":0,"warning_text":"","next_request_ms":10000,"epower_0_state":1,"epower_1_state":0,"used_for_devices":"[\"U85iFFgAG0Z7wrql0\"]"}
[COMMS] response TEMP (corrected) {"error":0,"error_text":"","warning":0,"warning_text":"","next_request_ms":10000,"epower_0_state":1,"epower_1_state":0,"used_for_devices":["U85iFFgAG0Z7wrql0"]}
When doing this I can successfully parse the json-array.
Not sure how the JSON is being constructed/serialised on the server...but maybe this article could be of help :
https://arduinojson.org/v6/issues/cannot-get-values/
For now I can fix this locally but maybe it's a good idea to solve this on the server.
Regards, Jos
Posted: Thu Dec 07, 2023 2:21 pm
Hi Jos,
Thanks for pointing it out! I'll fix it.
Posted: Wed Dec 13, 2023 5:31 pm
Short update: Should be fixed.
Btw... any device of type "bookesbrick" not only receives the used_for_devices but now also a "s_number_temp_offsetcelsius_0" which should be added to the display value on the device. This offset can be configured on the Bricks page.
