Hello.
I uploaded the firmware but I can’t connect to my Wi-Fi network, the device is active only as an access point, I register the password for the network ... but I can’t get the connection.
I have tried several options.
I was able to find out that I had WPA2-Personal network protection and only by disabling all network protection could I connect.
Fix Wi-Fi connection problems
Re: Fix Wi-Fi connection problems
Hey there,
unfortunately WiFi capabatilies are somewhat limited on the simple chips, just consider the 2.4Ghz limitation. If you happen to find it's a software issue, please let us know or submit a Pull Request on Github.
