Multiple Tilts in one brewery?
Posted: Mon May 27, 2024 4:39 pm
by trmccart
Hello,
I am looking at using the Tiltbridge project (
https://tiltbridge.com/) to get Tilt data to Bierbot Bricks. Can the Bierbot tilt api support multiple Tilts (different colors) in the same brewery with data sourced from the same IP? (At the moment I only have a single Tilt to test with.)
Thanks!
Re: Multiple Tilts in one brewery?
Posted: Tue May 28, 2024 5:28 am
Hey there!
Yes that's possible! Only thing you already figured out: colors need to be different. At least without tilt bridge
Maybe you can report back if you tested it so other know?
Posted: Wed May 29, 2024 6:15 pm
by trmccart
Great! Thanks for the response! I'll report back after I do a bit more investigation.
One more question... how does Bierbot use the Tilt "Timepoint" attribute in the posted data? The esp32 used for Tiltbridge may not be the most precise with timing. Is this a concern?
Thanks!
Posted: Wed May 29, 2024 8:42 pm
We use the timestamp when the message reaches our backend
Posted: Tue Nov 26, 2024 3:17 pm
by kimon
Yes, the Bierbot Tilt API can support multiple Tilts (different colors) in the same brewery even when data is sourced from the same IP. Each Tilt is identified by its unique color, so as long as your Tiltbridge setup is configured correctly to send data for each color to the Bierbot API, the system should handle it without issues.
Posted: Sat Nov 30, 2024 11:36 am
by sumit02
Hello.
Does the Bierbot Tilt API allow customizing the frequency of data updates for each Tilt color in the same brewery setup?
