User interface question.
Flemming
Post by Flemming »
How are the "Delete points in graph" supposed to work?
I cannot figure it out just by clicking around :roll:
I got a couple of values that are just bad data quality ad it messes up the graph :geek:
Skærmbillede 2023-12-05 134523.png (24.91 KiB) Viewed 15476 times
Re: User interface question.
Hi Flemming,
Thanks for reaching out! I'm delighted someone spotted this rather hidden feature. It's actually made for just that: removing outliers. I can tell you how it's supposed to work.
1. Click on the trash can
2. Click on a point in the brewing log
3. Point should disappear.
If that's not the case for you, please sent me a bugreport and include your API key.
Flemming
Post by Flemming »
Thank you for quick reply!
I messed around pr. your advice, and can SORT of get to work but not quite... so I will make a bugreport.
This raise 2 questions (sorry)
1: Is my API key the the "Username" i can find on the https://bricks.bierbot.com/#/profile page ?
2: Where / how do you want to recieve the bugreport?
Flemming
Post by Flemming »
For security reasons, I won't write API keys here, but I can still describe what I'm experiencing:
1: I can delete in the graph of Historical Temperature, but not in the graph of Historical Gravity.
2: It seems like temperature data points are deleted from the beginning of the graph up to the data point I click on - I'm not sure if that's what's happening, but it looks like it.
3: When a data point in Historical Temperature is deleted, I would expect the temporally corresponding data point in Historical Gravity to also be deleted to maintain consistency between the two graphs. It doesn't seem to be happening.
I hope my error explanation can be helpful.
Best regards,
For the bug report, either use the blue button on the lower right side or email us. API key will be displayed when you add a new Brick, but that's only required if you send an email, with the blue button you just need to toggle the "include meta" switch to "on".
What you describe sounds definitely like there is something off. I'll have a look
Flemming
Post by Flemming »
Okay - I clicked the blue Help button, and submitted a topic text withthe meta-data switched on.
Feel free to manipulate my data as you need... for the the brew I got online I only need to see when the yeast have done the job 8-) and that kind of shows directly on my iSpindel on the https://bricks.bierbot.com/#/brewery/bricks page so...
Hey, brief update: Should be working now :)
Flemming
Post by Flemming »
Awesome - thank you for your great work and have a happy holliday.
