Hello
I have a Google pixel 7 phone and cannot install the BierBot Bricks app.
Is it because the app is only in 32-bit? Is it complicated to post it in 64-bit version?
Arne
BierBot Bricks app
Re: BierBot Bricks app
Hi Arne,
thanks for reaching out. The app is currenty way behind the web version. I'd recommend opening the web-app (bricks.bierbot.com) and adding it to your homescreen. Feels (almost) the same.
Releasing native apps will receive more attention from me, when I start implemented a notifaction system (i.e. "active device offline" or "add hops now").
Vinnes Beer
Great, thanks it was a good solution when the phone is not responsive.
Arne
Arne
Hello,
I recently downloaded BierBot Bricks app from https://apktact.com/ and successfully installed it on my device, so I might be able to help! If the BierBot Bricks app is only in 32-bit, it could indeed be the issue since the Google Pixel 7 runs on a 64-bit-only architecture.
The best solution would be to check with the app developers to see if they plan to release a 64-bit version. In the meantime, you could try compatibility modes or alternatives, but there’s no guarantee they’ll work.
Let me know if you need more help!
That's helpful to know, thank you!
I'll explore the compatibility options and see if the developers have any updates on a 64-bit release. Your suggestion gives me a good starting point.
Regards,
Sumit.
Regards,
Sumit.
I'm a software developer working on amazing projects.
