The values in the screenshots cannot be trusted. I have juggled so much around with the settings, i pure desperation, that most of them are unreliablel.
My iSpindle is calibrated - using high sugar solution and diluting it slowly while recording tilt angle to get the correct calibartion values into the iSpndle Firmware.
Like I mentioned in first post - Everything WORKED flawlesly for my FIRST brew... now - a few weeks later - gravity is not recorded and no graph is showing.
I have also tried to use "Overwrite polynom to calculate gravity" using values from ducumentation(I know they do not fit 100%) just for test but it do not change that no datapoints are recorded in gravity history graph.
I just found that i can not enter gravity in log manually either?
This is really puzzleing me
ScreenShot 2023-10-16 082455.png (76.41 KiB) Viewed 37117 times
The popup shows up and i can input numbers and click Add - then a short animation shows up briefly but no datapoint is added anywhere as far as I can see...
Have the same problem with my new ispindel, all parameters are in normal limits, readings a stable evry 15min, no historycal graphics, just a point of curent temp and gravity in "manual" mode.
New Bitmap Image (4).png (68.74 KiB) Viewed 36996 times
