I've send you the API-key.
regards, Jos
Brew/Fermentation temperature versus used Brick
Re: Brew/Fermentation temperature versus used Brick
Hi Bernard,
Just a quick update from my end. Yesterday late (around 11pm) I got a response from the LCD API back. In my view I did not change anything regarding the LCD API code. So I saved the debug-log output of my Bookes-Brick. See below.
I quickly re-tested this morning, now suddenly the response is 'Internal' again! This is easily to reproduce by entering the request-URL in browser.
As mentioned before, the first time I see a response, go in to the UI an confirm the new display...but the secondary request returns an 'Internal' message.
There's a second remark. This thread started with the question if it's possible to link the a brew (or better: the brew-temperature) reported by the LCD-API to a certain brick. For this you added the "used_for_devices" field. So as can been seen in the log above, I got that response. Next I started a recipe called "Fermentation 2nd"...which is shown also in the log.
But the "id" field from the LCD-API and "used_for_devices" are not equal. So how should I link that information?
So now we have 2 questions in 1 thread...sorry
Kind regards,
Jos
[COMMS] response LCD API={"result":"success","error":0,"error_text":"","warning":0,"warning_text":"","settings":{"temperatureUnit":"celsius","displayBrewEveryS":5,"showLocalIP":false},"brews":[{"currentTemperatureC":{"na":-273,"primary":14.8,"secondary":-273,"hlt":-273,"mlt":-273},"id":"EelH8Kk7yVtJekgNCl7I","name":"Fermentation 2nd","targetTemperatureC":0,"nextEvents":[]}],"next_request_ms":15000}
[COMMS] TEMP API url=https://bricks.bierbot.com/api/iot/v1?apikey=XXXXXXXXXXXXX&type=bookes&brand=bierbot&version=0.2&chipid=233865988974512&s_number_temp_0=12.90&s_number_temp_id_0=0&a_bool_epower_0=1&a_bool_epower_1=0
[COMMS] response TEMP API={"error":0,"error_text":"","warning":0,"warning_text":"","next_request_ms":10000,"epower_0_state":1,"epower_1_state":0,"used_for_devices":"[\"ZkDZ3LqDbYFZdH9q9cBX\"]"}There's a second remark. This thread started with the question if it's possible to link the a brew (or better: the brew-temperature) reported by the LCD-API to a certain brick. For this you added the "used_for_devices" field. So as can been seen in the log above, I got that response. Next I started a recipe called "Fermentation 2nd"...which is shown also in the log.
Kind regards,
Jos
Hi Jos,
regarding your first question: I was not able to reproduce you error. Tried various times at different times.
Is it working for you now?
regarding your second question: I will create a separate endpoint something like /devices which will give a you a list of all devices and /devices/id123123id42 to get more information about the device. Would that help?
In the meantime I got responsed back from the LCD-API. No clue why this was happening. But happy that it works again
Regarding the 2nd question...not sure what you exactly mean. What is the definition of a device ? A temperature sensor or an actuator, or a Brick?
Regards, Jos
Regards, Jos
Kind reminder to have a look at my last question.
Regards, Jos
Regards, Jos
Hi Jos,
sorry I forgot - thanks for the reminder.
There are four levels:
- Interface: Something like a temperature sensor or relais
- Brick: A device like a Sonoff TH, Raspberry Pi, TILT, iSpindel
- Device: Virtual aggregation of interfaces from one or multiple Bricks. Surfaces under the equipment page. Examples are "Fermenter" / or an instance of a Mashtun.
- Brew: Combining one or more Devices into one process which is being tracked.
Makes sense?
Makes sense?
Hello Bernhard,
You wrote:
Kind regards,
Jos
You wrote:
Could you please give a short example of this? I'm not completely following what you mean.I will create a separate endpoint something like /devices which will give a you a list of all devices and /devices/id123123id42 to get more information about the device. Would that help?
Kind regards,
Jos
Sorry to bother you once more...could you maybe provide an example?
Regards, Jos
Regards, Jos
Hi Jos, I'll try to implement it on the weekend and provide you a working example here. Cheers, Bernhard.
Hey Jos,
I got something really nice cooked! API is available and documentation can be found here: https://docs.bierbot.com/developer-section/pro-api
You just need to go here https://bricks.bierbot.com/#/brewery/admin and enable it.
Please let me know if you have further questions.
Thanks for your contributions,
